What should my rear pinon angle be? (lots of info)
allevolution
Chicagoland
2000 XJ, NP231
Almost exactly 4" lift all around
Currently swapping my d35 for a 825 I got.
I am using:
-IRO hack n tap
-OEM front shaft
-RC lift Shackle brackets (1.5")
What (in degrees) should my rear pinion be?
I have various axle shims and I need an idea where I need to point my pinion
it needs to be inline... so telling you exactly what degree isnt possible until you install everything.
having it point slightly down isnt a bad idea either, as itll account for pinion change during acceleration.
High angle driveline told me 2* down.
I believe its because the axles will rock back slightly under acceleration
