What rear leaf spring pack?
Tony_SS
NAXJA Supporting Vendor
Washington MO
I have stock leafs with an AAL, stock shackle.
I'm looking to get ~4.5" total.. so I'm thinking a 3" leaf pack an an 1" shackle. I like the JKS shackle unless someone can tell me different.
What leaf pack would you all recommend?
I have had the IRO 3.5 complete pack for a year. With 1.5 lift shackles.
Sits about 4.5-5inch. Rides really good has good shackle angle., and flexes
Really good.
IRO X3
IRO makes a descent military wrap 7 leaf 3.5" leaf pack. Jks 1" boomerangs are what I run for shackles
Are those IRO 3.5" leaf springs longer that the OEM set? I need to get a set for my XJ.
I have the BDS 3" leaf pack. nice ride, maybe a little stiff. Definitely designed for more weight.
I'd recommend a 3" or 3.5" leaf pack and a shackle relocation / conversion for the extra 1".
I built bastard packs, using XJ leaves for the donors. About 1" lift for each leaf I added. Rides nicely, was dirt cheap & surprisingly easy. Just throwing it out there as an option - you could probably hit 3" of spring lift if you use the three top leaves from each donor, add a 1" shackle or even better a shackle relocation bracket...
