what product fills small holes best?
JrTxJ
Canton, MA
i removed the rear brackets that hold on the end caps, and now i have the rivet holes left. i know this may seem simple and bondo comes to mind quickly, but i was wondering if anyone recomends anything else that works better or easier? i have 3 holes on each side and i plan on filling and repainting either stock patriot blue or bedlining the area...i just want to know if there is a faster drying product that works like bondo, or if i should just use that.
any help is appreciated, thanks!
Depends on whether the holes are in a structural member or not - I'm guessing not...
You can get a two-part filler (like Bondo) but metal-based, rather than poly. Look for it at welding supply shops and body shop supply houses under the names "Lab-metal," "All-metal," or "Metal2Metal."
Also, for small holes, it's possible to use a two-part "putty stick" metal-bearing epoxy for hole filling. JBWeld can be used in a pinch, but I'd probably use JB-Kwick, and back the hole with some sheet copper (helps to fill the hole, and JB shouldn't stick to copper - old welder's trick...) to keep the stuff in the hole until it sets.
If the part is structural, I'd suggest just welding or brazing the hole closed. However, the two-part metal fillers and the "putty stick" are both going to be easier to sand to finish.
I never did like the idea of filling metal with plastic...
5-90
langer1 said:
Bad news the faster it sets the weaker it is.
i didn't mean like a few minutes, i just meant in general so i could paint over it in a relatively short time period / same day.
thanks for the suggestions guys...
