Jeepguy03
- Connecticut
What is the correct way to install a trans cooler in relation to flow? I have a B&M Supercooler on my XJ, but I don't have a temp gauge yet. From reading a couple threads on here, I think my trans cooler is installed wrong. Mine is a stacked plate cooler and is installed with the hose barbs facing down like shown below:
My friend also has a 2000 XJ and we installed a flex-a-lite tube and fin cooler on his. How should this one be installed?
It looks like this:
I just want to make sure I have the hoses routed correctly. I ran the hose from the tranny return line on the radiator to the cooler, then from the cooler back to the tranny on both Jeeps. I just want to make sure I have the coolers set up right. It seems as though the fluid should be going in the bottom barb and out the top according to some threads. Is this the same for stacked plate coolers and is mine installed sideways?
Thanks!
It looks like this:
Thanks!
