what else for a teraflex4" longarm kit?
crash02
i have a 1989XJ and i just purchased teraflexs 4" longarm kit, i was woundering what else i need? (limit straps,brake lines, t-case drop,etc...)
i bought a basic kit from offroadwarehouse.com for 604.99
i also got bilsteins 5100,and RE track bar. i was told that i did not need limit straps (but i don't believe it),and could go without extended brake lines. i will be doing some crawling along with jeepspeed (style).
all ideas welcome and considered. thank you
crash02
possibly a t-case drop or a SYE, every XJ is different and i would go with the longer brake lines, get yourself some 95 or 97 TJ lines, they are longer and cost $20 each at autozone, as compares to $30+ for aftermarket lines.
and thats all i have to say about that.
I would agree on getting new brake hoses as well. Been a while since I had my stock brake hoses, but I am quite sure that if you use stock hoses with the LA kit that they may become your limiting straps.
I have the Tera LA but not their 4" LA kit. I don't have any limiting straps at this point, but may pursue them later. Not sure what is stopping my frontend's downward movement, shocks, trackbar, arm bind...
i went and picked up the 97 tj brake hoses, but i am going to wait till i install my longarm kit. i placed the tj hose next to my already mounted stock hose and it dosn't seem much longer? but if it still isn't enough then i was told to either unmount my brake line from the frame or just relocate it lower, eitherway thank you for the advice i saved easily over 30 dollars.
i will also be putting limit straps on to help out. im just not sure of how long i need yet.well thank you and more advice is always welcomed and considered.
crash02
i hope i wasnt wrong but they could have been the yj lines i will have to check my sources, but if i was wrong you can take them back and get the others so keep the receipt.
YJ=95, TJ=97.
I've always read that YJ lines should be used. I'd just get aftermarket stainless steel braided lines.
Fred
crash02
The correct lines to order if you want longer front brake lines are from a 95 YJ. I bought these for my Jeep, they are several inches longer than stock XJ lines. Edit: you can also remount the hardline a few inches further down on the unibody, just unscrew, redrill and screw the mount in the new hole.
