What do you need to get done before WF?
TORC811
Davison, MI
What does everyone's list look like?
I have to do rear drive shaft u-joints, get my rear locker to engage and rewire my e-fan.
Install lift kit
Install rear axle shock relocation brackets
Install front LCA mini skids and UCA bushing bracket
Revolution 4.56 Gears - On backorder ETA TBD
Ten Factory front and rear axles
Install front/rear ARB lockers
Install timing chain
Oil pump, pan gasket, rear main seal
Big 7 Jeep Cables Upgrade
Finish rebuilding 160A Durango alternator
Rebuild starter
Install all new cooling system components
Install all new a/c system components
Install AJ's rock sliders
Finish installing IRO front stiffener kit
Install IRO gas tank skid (purchased at 2021 WF, still in basement)
Weld up DIY front bumper (SFR)
Weld up DIY rear bumper and tire carrier (Dirtbound)
Reinstall interior (removed for bedliner and heater core replacement)
Reinstall doors (removed for hinge pin replacement)
Exterior Raptor Liner
Reinstall front and rear glass
Install brackets for carseat tethers
You know... just a couple of loose ends. :roflmao:
Check fluids & get 2 ton of frozen rock off the trailer.
Install lift kit
Rebuild starter
At least it's a short list! Lol
Sent from my SM-G981V using Tapatalk
Get the RV and trailer out of the barn...
mac 'hope the mice stayed away' gyvr
Tow rig is home from the stealership. Heading to the in-laws tonight to drag the trailer out.
I suppose I should start working on a Jeep.
Change fluid and filter on trans and check noise in transfer case
