What do you have to get done before ROM?
IslanderOffRoad
Houston, Tx
Finish the Deaver spring install
Finish the fender flares on the right side
Adjust my front control arms to improve caster and ride height (springs bowing currently)
Maybe add a spacer up front to match where the deavers end up
Taking off Friday to finish the Deaver project since I had to work this weekend.
Get my front drive shaft rebuilt and installed
Figure out the leaking ABS pump/brake system upgrade
Clean the interior
Grease all door lock mechanisms
All I gotta do now is:
Check brake fluid
Kind of clean the interior
Get trailer
install new headlight harness relay
work on header panel/headlights
tinker with rear hatch mechanism. keep slipping off the lever
maybe get light bar installed.
hope my tires make it another run. holding off on new ones
