rav
- Albany, NY
Dino good to see you here, BTW i was hoping to see your bid on the intake, looks like you were to jet lagged, also need your final verdict on my setup now that i am getting the Venolia pistons and eagle rods. How much HP do you think i will make???, any suggestions, you know we all treat you as the 4.0 God!!!!Dr. Dyno said:Where did you hear that? AFAIK, all the 4.0 heads have chambers in the 56-58cc range. I agree about cc'ing everything so that you know exactly what CR your engine has. There's enough variation in manufacturing tolerances to cause a variance in CR of 0.2-0.3 between engines build to the so-called "same spec".
Ravi
