Zuul99
- Scottsdale, AZ
$100 for my Delta H4 55w conversion kit with halogen bulbs
Honda relays fit the Putco/e-autoworks harness. A whole pocketful of relays cost me $2 for admission to the junkyard.
e-autoworks Honda relay
Honda s2000 2000-2007, Pilot 03-07, Prelude 97-01, CR-V 91-01, Odyssey 95-98, Civic 2d 96-00 or 4d 98-00, Accord 2d 98-02 or 4dr 98-02.
The Honda part number is 39797-SE0-004
I believe that those are "micro" relays as opposed to the standard Bosch ice cube style which are considered "mini" relays.
Just an FYI. Installed my Cibie 'E-code' H4 upgrade from Daniel Stern today ($380 w/harness and shipping.. yeah, I know $$$). Top quality stuff.
The FYI is that when I finished the installation (4 hours on my own) the high beams would not shut off when I hit the dimmer so I ended up with both Hi/Lo lit when on Lo. Puzzler.
Solution: I have an aftermarket winch bumper and the factory fog lights are disconnected but the wiring, switch and relay are all still in place. After a lot of monkeying around I called Daniel. After pulling the factory Fog Light Relay out of the box under the hood, all was well and working as they should. Daniel says this is common on Subaru but that he'd never seen it on a Jeep.
Also, sometimes aftermarket relays for driving lights might cause the same issue, he says. Then it's a matter of wiring the driving light relay to the new wiring harness Hi Beam wire instead of the factory Hi Beam wire. Since relays require such a small voltage to activate, enough can bleed and activate the Hi Beam relay when not wanted. Same for the fog lights if you want to keep or add them. Just wire the relay that goes to the Lo Beam wire away from the factory wire onto the new harness Lo Beam wire.
Great response from Daniel when I needed him. That's very important to me. http://www.danielsternlighting.com
Also, the aiming procedure from his website is awesome. Sounds complicated when I read it but is really simple and fun and it's good to know my lights are properly aligned. Now I have permanent marks on the inside of my shop door so I can check and realign if/when needed. Now I have to take it for a spin to see if I can see. I might have gotten away with just a harness and relays but figured I'd go full-on from the git-go. The old lights were not good as you well know.
Thought this might save someone time if they run into the same issue.
It's not your fog lights causing that, its happens on some of our rigs from that goofy delay module under the dash. Just unplug it.
Also if you want to get the fogs hooked up with your new harness, look for the thread I posted. The red fog light relay wire, on the driver side, needs to tap into the high beam on your new harness.
Everything will work correctly if you do those 2 things.
Thanks, but it was the fog light relay. I do not have (or want) fog lights but the factory fog light relay was still in place. As I said in my original post, once removed everything is functioning as it should with the new harness, including the aftermarket Vision-X driving lights.
Has anyone tried these?
http://www.quadratec.com/products/97009_8002.htm
$449 from Quadratec.
Gawd, I cant wait until the price on LED's gets reasonable...
$179 from Drivetrain America.
They look promising? I might consider these only if they are legal and won't throw light all over the frikken' place. I'm not going to be that guy.
That's $179/piece + shipping. I'm sure you'll need two. I mentioned back in post #18 that I am running these. I bought them back a few years ago. The are legal and they work.
Still $100 cheaper than Quadratec, which is usually outrageously overpriced anyway.atriot:Also, I clicked on the YouTube link in your post and it's dead. :dunno:Edit - Just a bad link. http://youtu.be/ZwUrSM9T2Tg
This is something I have always wanted to do since i swapped this front clip, the problem is what the hell kinda headlights work in this set up?
