- Vancouver, WA
Let's fight!!
That looks just like Scott and Andy!
then bit the hand that feeds me.
:canada:
This sounds kinky, do explain?
:loveu:
I prepared the brackets for their union. I cut the weld nut off of the end of the JCR nut-strips. Then, I cut the end off of the Tailbone bracket. In the picture below, the original pieces are on top, the modified on bottom.
I tack-welded the two together to hold them steady while welding the rest of the bead. Note the differences in thickness of the two materials. This was a challenge for my first weld, becasue the heat can burn away the thinner material without fully penetrating and bonding to the thicker material if you don't perfect the technique and speed variations in your arc movement. Considering this is my first official weld to be used for on the Jeep, it was a challenge! (I had ran some practice beads on scrap metal for 5 or 10 minutes prior to this as my truly 'first welds' . . .) I have a great friend who is teaching me on his 110v Lincoln MIG, and he is very encouraging and motivating.
My first weld! I went a bit slow at the end, causing some extra material to build up as seen in the top of the picture below, but I'm proud of that section in the middle, even if I did have to double back real quick while the pool was still molten. I started out the bead at the bottom of the picture, and I went a bit fast (scared to burn through the thin nut-strips), causing some gaps. I truly spanned the gamut of possibilities (mistakes!) didn't I?
I also ran a bead down the back and ground it flush, as this is a mounting surface. I think it looks like pretty decent penetration where I ground it down, because it appears to be a single piece of metal.
I'd be happy to hear any critique or suggestions for improvement.
I rolled mine on to its roof after I lost the breaks. kind of hurt it a little.
I put a new gas tank in that doesnt leak like my old one. Now i just need to find a passenger seat.
Nah... Riding in the backseat with no front seat is actually pretty fun. LOTS of leg room
That reminds me I still need to buy a CB. I think I'll go buy one of them handheld CB's that you posted in the X-mass gift post last year.
