I swapped out the T-cases today Everything worked well, both had 23 spline count and the 231J already had a AA short shaft "fixed yoke" kit already installed, I need to order the proper gear for the speedo though as previous owner had it geared for 32" tires where as I am running 31". The rear double cardan joint shaft looks like it is stretched out to the limit which makes me a little nervous.
Now I have another question I hope someone can help me with?
Here is the measurements I got using an angle meter, can you tell me what degree of shim I require? and please explain to me how you got the measurement?
will not let me load pic??????????
Can I use the same formula for the front diff as well? I realize there is steering angles involved, I have had the front end alignment and it tracks well however not sure about the caster angle as alignment shop said it was within specs. I have adjustable lower control arms
