time2getdirty
my cats breath smells
- Cheyenne, Wyoming
One ton, if you don’t have any gauges you don’t have to worry about lights.
Lol, hopefully......
Mopar still makes 4.0 cranks?
All I know is it was a pre facelift and he always said it was the highest most fully loaded you could get ��*The hood and fenders currently on it are from a red 95 so maybe it’s a cross breed?
Nerd.
You pull the engine and slap in the crank or fight it in underneath?56027866ac Mopar $90 shipped . The master pro was $20 . This issue popped up when I was getting ready to head out for work so not much time to look into it , but My wire harness is very easy to trace since it's all visible running from the engine bay left side and right side back to the tail . I had an issue 6 -7 years ago the jeep would stall going from reverse into drive turned out when I installed the transmission I forgot to final torque the block to bellhousing bolts and I had about a 3/32nd gap between which was my issue causing it to stall shifting between reverse and drive ... My current issue could be something as simple a a ground or as much a pita as a flex plate causing the misfire .
I think you missed the sensor part of him saying crank shaft sensor.
Some pictures of the xj buggy. 4.0, rad shifted aw4, 231, jk d30/44 with 5.13s rcv shafts front and rear, tnt suspension all around, body ditched, 38” sticky’s.
has anyone tried Nick Risely's 4 wire O2 sensor mod?
