WF semi-built 1987/93 Waggy part out
Status
Not open for further replies.
XJ&CHZ4ME
Unionville, MO
OK gang, I finally drug the waggy home last night and I am going to part it out. All parts are available for WF delivery, but the more expensive parts I will want a partial or full payment before I drag them 8 hours out. Yes I have Paypal, and I accept or cash in person on certain items. OK Here is what the rig is, and I will list some of the "high" points, if there is anything else you are interested in, hit me up and we will see what is there and condition.
1987 Waggy w/ a 1993 full HO drivetrain swap w/ 4.0/AW4/231 all done with proper harness and ecm etc. Runs fine, has @140K on it I think, but will verify later today..
Axles: D30/D35 w/ FACTORY 4.56 out of an early 4 banger. the D35 has been welded, don't ask me why. The D30 will need spider gears since I took the locker out of it. $400/pr or $400 for the front with a free boat anchor. :D
4.5" Rough Country lift coils $65
1.75" spacers $30 http://www.roughcountry.com/coil-spring-spacers-7594.html
6.5" Rusty's full leaf packs w/ newer bushings. $250 http://www.rustysoffroad.com/jeep-s...ngs/rustys-leaf-springs-xj-6-5-rear-pair.html
NP231 t-case w/ AA SYE installed (under 100 miles since SYE install) $225 http://www.roughcountry.com/np231-slip-yoke-eliminator-50-7906.html
Rustys' HD steering with all new TRE's. It is not a 1 ton set up, just the HD factory replacement they offered. $125
http://www.rustysoffroad.com/jeep-s.../rustys-jeep-xj-tj-yj-tie-rod-conversion.html
Rough Country adjustable track bar $75 http://www.roughcountry.com/adjustable-track-bar-7572.html
Rough Country drop pitman arm $25 http://www.roughcountry.com/pitman-arm-6605.html
Rough Country extended stainless brake lines $50 http://www.roughcountry.com/extended-front-brake-lines-89702.html http://www.roughcountry.com/extended-rear-brake-line-89703.html
Rough Country Drop brackets $125 http://www.roughcountry.com/jeep-xj-control-arm-drop-kit-1627.html
Waggy header panel (will get better idea of condition later today) $100
33x12.50x15 AT type tires, low tread $80
4.0 with AW4 tranny still hooked to it, runs and shift good. $300
Homebrew rear bumper that works w/o having to cut n fold $100
(2) front drive shafts $35 each
If there is anything else that you may want, hit me up and I will check condition and availability. All prices are best reasonable offer. Will ship smaller items at buyers cost.
I may have 2, I have not even looked at all the parts he threw on the back seat. I will let you know what I come up with.
Can you text me a picture of the rear bumper Tyler? I may be interested.
Uh, put me in line on the header panel. If anything I need the turn signal lenses.
will do. I think that it has an extra header panel in the back for parts, so if it has the turn signals, I will let you know. I plan on looking things over today pretty good since I did not get home last night until dark.
Collin, bumper pic text incoming.
Dan, header panel pic text incoming. It is of the one that is installed n been painted over, BUT it has an extra inside I found with both quad bezels n signals in really good shape, but grill is missing a few bars. Ill try to send u a pic of it later, I left my phone in the house when I found that one.
Waggy header panel (will get better idea of condition later today) $100 SOLD
Homebrew rear bumper that works w/o having to cut n fold $100SOLD
Is the Rustys steering set up bolt in? I need to replace my TREs and wanna upgrade my tie rod, this may be the way to go for me
Anything else on the header panel/side lenses?
Dan bought the panel with the lens in it, I did not have any extra outside corner lens after looking. The extra lens I have ate the ones in the bottom of the grill n I don't want to sell them seperate from the grill at this time.
Yes, it is a standard bolt in set up. Just adjust to your level of lift n you are ready to roll.
Rough Country Drop brackets $125 SOLD
Homebrew rear bumper that works w/o having to cut n fold $100 SOLD
Just the ones in it. It was upgraded to a solid shaft on the passenger side. Not sure if drivers side small or big joint.
Status
