VegasAnthony
- Las Vegas
jsut wondering if anyone has just welded tow hooks to a HD bumper or are the bolts a must
Eagle said:What I have read is that tow hooks are forged, and welding screws up the temper, causing embrittlement.
Not a good idea. We don't allow welded hooks at NAC events.
X2...Eagle said:What I have read is that tow hooks are forged, and welding screws up the temper, causing embrittlement.
Eagle said:Not a good idea. We don't allow welded hooks at NAC events.
How about you weld up a bracket and then bolt the hook to the bracket?BIG-G said:Well i just bought a set of hooks with retainer clips. Gonna bolt em thru my front push guard which isnt much of a bumper and would probably bend it trying to tow it using the hooks. So, gonna give em a weld then weld up added supports to the frame and bumper off of the push grill guard and i'll post results.
Lawn Cher' said:Big-G, if that push bar is just bolted to the stock bumper, it is not an adequate tow point regardless of how much extra crap you weld to it. Find another way.
Kejtar said:How about you weld up a bracket and then bolt the hook to the bracket?
Ramsey said:lets see some pics of those nerf/sliders
BIG-G said:Not a bad idea, i'll try both and test which works better/stronger.
Don't bring it to a NAC event to test it, either. Do it right or don't do it at all.BIG-G said:Not a bad idea, i'll try both and test which works better/stronger.
