Welding ball joints?
Vanquish
Canada
K so my passenger upper ball joint is loose in its hole. The play is easily noticable when you wiggle the tire.
Any tips or tricks to perhaps fix this? I installed MOOG joints like 4 months ago, so it shouldn't be a "made in china" type thing...
I think I'm going to put 3 small welds around it and pump the grease to her to keep her cool.
...unless someone has something better of course...
:piratefla
remove the ball joint, and inside the hole take a a center punch and start pinging it all the way around, top to bottom, this will expand the metal in the hole,thus making it smaller and hopefully tighter fit, theres actually a name for this process. cant think of it right now. id give that a shot first.
Id try a new ball joint first,then Id just replace the axle.
