Will a 29 spline 8.25 survive being spooled? Does anyone make a spool for 8.25? I couldn't find one. What about welding the spider gears? Anyone done this? I'm running 32's, soon to be 35's. Thanks!
Don't weld the spider gears if you plan to ever drive it around a turn on the street. Not to mention if the weld breaks it will not only break it will take everything else with it. Just my 2 cents.
driving welded on the street isn't much of an issue, you get increased tire wear, and that funny chirping/squealing/people giving you wierd looks around corners and all, but other than that it aint so bad....and don't throw it away, recycle!
Yeah, I'm not anti-welded or spooled axle. In fact, I'm putting a spool in the 9" I'm building. I'm just saying that with a welded c-clip axle...there is no way to get the c-clip out to change the shaft if it breaks. Hence, the recyclable 8.25 when you're done.
I'm planning to change the rear to a 8.8 for the disk brakes. otherwise I would go for the 44. Don't want to spend money for a locker on the 8.25 just to take it out later.
Dont they make spools for the Explorer 8.8? IIRC, that is a c-clip axle. Granted it's used in alot of applications, probably more then the 8.25, and thus why there's spools for it.
I dunno how you supposed to weld the spiders together, but we welded my Dana 35 (non c-clip, and NO, I don't plan on keeping it long, just wanna see what the spool idea is like) about a week ago. IF there was c-clips, you could still access them with the way it was welded. BUT, a 8.25 carrier might be really diffrent, so I don't I know if this will work.
