I'm having issues again. Once you try to give the XJ some gas, it feels like well the cat is clogged or when the CSS is going bad. Rough idle, hesitation at 2,000rpm and beyond, like it's going to die. The CSS is new as of Thursday, and the cat has only 15k miles. I have check vacuum lines (could have missed one), the TPS, MAP, and the cap and rotor. Any ideas? I'm stumped on this one because everything that has caused it to do it before doesn't work now to fix it.
My lease is up on the car Friday so I need the XJ to go back into DD status for a few months again. Thanks, Juice
