has anyone used a few washers on the lugs to make up to the smaller 8.8? i'm not talking about using washers to make up the whole 3/4 that wouldn't leave any lug left. but like 2 or so just to get alittle back?
Oh HELL no! Use a real spacer that bolts to the axle and has its own lugs or just use a rim with less backspacing - the cheap spacers that rely on a longer lug and are simply sandwiched between the rim and the axle are dangerous enough without getting super-cheap by using washers instead...
it realy isn't that bad i mean 3/4" is the total that it is short that leaves 3/8 of an inch shorter on either side. i can't even tell if i try when looking at mine. although my stock rims with 31x10.5 tires did rub on the leaf spring clamps
