WARN Rear Bumper and Tire Carrier
nijburt
NC
WARN Rear Bumper and Tire Carrier For 84-01 XJ with mounting brackets, hardware, and two WARN D-shackles - $750. There's some minor surface rust on the mounting brackets and minor damage to the vertical post on the tire carrier (will post pics of this) but it shouldn't be hard to fix. Selling it cause I'm tearing down and rebuilding my XJ.
Man. info:
This rear bumper is designed with off-road performance in mind. This bumper sits high and tight, and is sloped to maximize departure angles & ground clearance. Welded eyelets will mount D-ring shackles, creating anchor points to increase your vehicle recovery options. The bumper is constructed of 3/16" and 1/4" steel that is laser cut, CNC formed and welded for precise fit and durability. The heavy duty Tire Carrier is built to carry up to a 36" spare. A license plate mount and handle are integrated. Available in black powder coat finish. Compatible with factory and aftermarket rear receivers.
Pix here:
http://www.cherokeeforum.com/f11/warn-rear-bumper-tire-carrier-pinehurst-nc-81987/
No delivery - Serious local buyers - Cash or PayPal accepted
