Winches 8500 & 10500lbs
RWKHausSupply
Available with either steel or synthetic line. Syn about 199$ extra.
Durable. Tough. Affordable. The Heavy Duty 8500 LB Winch from Rugged Ridge is everything you could want in a winch.
It is driven by a durable 5.5 HP Series Wound motor for long life and extra pulling power. A tough 3 Stage Planetary Gear box with a 172.8:1 gear ratio delivers power and reliability on each and every pull.
The Heavy Duty 8500 LB Winch has more power and exclusive features than any other winch in its price range: Stainless Steel Hardware- All the exterior winch body screws and bolts are Stainless steel to prevent rust and provide a long life. All Rugged Ridge steel cable style Winches include off road light mount roller fairleads allowing for the easy mount of two off road lights! Special Solenoid mounting brackets allow for multiple solenoid mounting points and the ability to “tilt” the Solenoid for ease of use. This “tilt” feature ensures that each Rugged Ridge winch can be used with almost all off road bumpers and over riders!
Limited 2 year warranty against manufacturing defects (1 Year on electrical). Each winch has been independently tested to ensure they meet or exceed all specifications.
8,500 lbs with steel cable - 299.99$ NEW direct.
Heavy Duty 8,500 LB Winch Features/Specifications:
• Durable 5.5 HP Series Wound motor for long life and extra pulling power
• Tough 3 Stage Planetary Gear box with a 172.8:1 gear ratio
• Includes 94’ of 5/16” diameter wire rope and latched hook
• Automatic load holding brake system (in the drum brake system)
• Exclusive light mount roller fairlead included- allows for easy no-drill mounting of up to 2 off road lights!
• Tough stainless hardware on the body of the winch to eliminate rust
• Each winch includes a durable 12’ all weather cable remote.
8,500LB LINE SPEED & AMP DRAW-FIRST LAYER Line Pull Lbs
NO
2000
4000
6000
8000
8500​
Kgs
LOAD
910
1814
2720
3630
3850​
Line Speed Ft/min
37.2
18
13.1
10.2
8.2
7.2​
M/min
11.4
5.5
4
3.1
2.5
2.2​
Motor Current amps
70
190
260
335
410
425​
10,500lbs with steel cable - 399.99$ NEW direct
Heavy Duty 10,500 LB Winch Features/Specifications
• Durable 6.6 HP Series Wound motor for long life and extra pulling power
• Tough 3 Stage Planetary Gear box with a 218:1 gear ratio
• Includes 94’ of 23/64” diameter wire rope and latched hook
• mounting of up to 2 off road lights!
10,500LB LINE SPEED & AMP DRAW-FIRST LAYER Line Pull Lbs
NO
2000
6000
6000
8000
10500​
Kgs
LOAD
910
2720
2720
3630
4762​
Line Speed Ft/min
29.5
14.4
9.85
9.85
8.7
7.2​
M/min
9
4.4
3
3
2.65
2.2​
Motor Current amps
70
170
310
310
380
425​
I am not sute. I will have to check in the morning.
