Wanted: Crank-Position Sensor...
Tenny
Houston, TX
Ok, this is a strange "wanted" I am sure...
I've had it hooked up to a snap-on diagnostic tool, and it was reporting no rpm when cranking.
Anyone have a working one? I replaced mine due to a no-start, but it still doesn't work. I just want one to test really to verify that is the problem, and it's not some other electrical problem later down the road...
they are 9$ up to 30$ on rockauto.com pretty quick shipping. did you check all grounds ?
Didn't realize they were so cheap on RockAuto.
Yeah checked the grounds everything seems to check fine (even the CPS).
I'm going to check the resistance across the CPS wire to the ECU, and if it's good I'll just buy another from RockAuto. If it's not good then I think I have found my problem... lol.
