Wagoneer rear Dana 44, 6 lug
yossarian19
Grass Valley, CA
It's been torn down for cleaning & check-out. Mid project I decided a Dana 60 was more like what I wanted. That's just how I roll.
Anyway, it comes with a trac lok carrier + an open carrier, 3.54 gear set. I can put it back together with the open carrier if you want to go lunchbox locker or leave it as-is and you can rebuild it with the limited slip.
No brakes on it. Run '92 Chevy half-ton rotors & calipers, Ebay the drum brake parts, or custom shafts & ZJ / TJ disc setups would work.
Text is best. area 5-one-oh 677 5857.
Located in Grass Valley, CA
