Viair 88p replacement hose?
iwannadie
Gilbert, Az
I love my little Viair 88p compressor but I hate the screw on tire chuck. I have a Viair infaltion gun with gauge that I would much rather use. What's the best way to replace the hose on these things? Under all the plastic it seems like it's a glued hard plastic pipe over a barb coming from the compressor then to a plastic juntion for gauge/rubber hose. No standard threaded fittings.
Is it best to just cut the tire chuck off and use a threaded hose repair fitting then use whatever fitting I want on it? Or, remove everything back to where the plastic pipe comes out of the compressor? I'd only use it for inflating and the built in gauge has been pretty useless especially if I can use my infation gun with its own gauge.
