- MilkyWay Galaxy
water pump is wrong direction
No, nice try, but try again. Hint, it is Renix radiator, still a closed system.
EcoMike, thought you we're playing with eveyone when you made this post. You, 5-90, etc. helped me with an '00 w/ the same problem. I KNOW the Renix is a different animal and you have much more experience on these Jeeps but hear me out.
Really think you were on to something cleaning off the o2 sensor from page 1!!! Unless I missed something you ran much cooler there than with any other effort, right? Isn't it possible that unplugging the O2 sensor would perhaps just leave the reading stuck with the ECM and a cleaning masking the problem? Myself and a coworker had the exact problem on our '00's with some cutout and after doing about everything outside of replacing the radiator and having his mechanic bench test those O2's he took it back in on the rack and found 2 of the 4 O2 sensors were out of whack. Replaced and ran perfect again. Just an idea, hope it helps. Oh, there were no codes either in our situation.
So you are not worried about running in rich mode? Is there a way you can tell? You must have some way to know, because I am pretty sure that you would be monitoring that.
