- Foresthill, CA
I've had a nagging problem with my steering since the end of last summer, when I boiled the PS fluid while playing in Little Sluice Box.
When I start my rig in the morning, I have no PS until I jerk the wheel a bit left and right, then it frees up, and feels sort of normal. The problem has been getting worse, and after this weekend's Johnson Valley fun, the problem appears to happen even while the truck is hot and running. There were several times on Sledge when I lost the PS entirely (let me tell you how fun it is to turn 10 psi MTR's on JV rock ), and then it would sort of come back on its own accord. The other part of this problem is the PS box appears to have difficulty self centering when coming out of a turn. It's almost like the feeling when the adjustment screw is set too tight, and the box gets sticky, but not quite as bad. This only started after the aforementioned Box boiling incident.
In short, WTF is going on with this junk? The PS box is a Kragen (I know, I know ) rebuild that is about 2.5 years old. The pump is about 5 years old. Both are OEM replacements for a 1988 XJ.
The second problem I can live with, the first gets very frustrating while trying to navigate tight rock trails!
CRASH
CRASH
