What the problem, did you break yours off or you not getting a good seal?
If you are not getting a good seal try a couple of pennies under than handle. If you broke it then head to the junk yard and get one. I think you just push out the pin and it will come part.
Be careful on "which latch"... Some of the production (I believe sometime earlier than your '91) mounts the latch in a round hole in the glass, your '91's should be mounted in a double-stamped round - kinda ovoid looking hole (taller than it is wide - if that makes better sense)
I have a '88 Wagoneer XJ which is a part vehicle for my '87 Wagoneer..... It's in really good shape, so if you are in need of anything and you know it will fit....let me know.
