Vacuum Testing
jeepsrock
LA California
I want to test my vacuum lines this weekend, so i went to autozone and rented a vacuum pump and gauge from them. I am guessing that i should plug in the gauge/vacuum pump to certain lengths of hose and see if they hold vacuum. My question is what is a reasonable pressure to vacuum too ? Would it be at all useful to have the gauge connected with the jeep running , to monitor vacuum readings ? What should they be ?
Thanks
pete
Thanks
pete
The first step is to check the vacuum at the throttle body. (pull a vacuum line and hook up the gauge.) It should run about 20 psi. If it's much lower, then you probably have a leak and should check the hoses/manifold/etc. If not, donworryboutit. :)
For hoses and fittings, you should test to the max the pump will pull. They should not leak down at all.
It's a good idea to monitor vacuum with engine running too, to see if there are any manifold leaks. While you're at it, it will tell you a little about the condition of your engine, valves, etc.
Yesterday i plugged in the vacuum pump with the engine off and i kept pumping but got little to no vacuum. I was able to hear a slight psss but havnt identified from were yet. I was planning on getting some vacuum hose from the auto store but after i went today they wanted 1.10 a foot, isnt that a bit expensive especially if i wanted to replace large portions ? What size do i need ?
pete
Today i found the vac leak from the vacuum canister. Apparently the canister itself was cracked, i went to the delaer picked up a new one and replaced it. After installing it i have vacuum if i use the hand pump.
Also i used the gauge like matthew currie suggested with the engine running. On a cold start idle my vacuum was at 15inHg or -50Kpa. The needle pretty much stuck to those numbers and moved less than a mm in one direction every once in a while.
So what does this mean ?
Pete
I have heard 20 in of Hg, but I am still trying to confirm, mine is at 8 right now and my car runs like crap
But it sounds like the canister may hvae fixed your problem?
eze
ok, as a newbie can comeone give me the proper procedure to test the vacuum?
Is it as simple as pulling a vac line and plugging in the guage?
Pete
Out of curiosity, what did the canister cost?
Parts that have a high usage volume tend to be pretty cheap. The flexible vacuum harness for the D30 disconnect was about $10 as well.
