D dobesrgrt NAXJA Forum User Location PA. Apr 19, 2012 #1 99 4.0 Am I suppose to have a Vacuum line coming off of the Map Sensor ? There's 3 Vac. line's below it in the intake but the one on the Map is capped. I don't know if this is right.
gradon NAXJA Forum User Location DC Apr 19, 2012 #2 96+ throttle bodies have a nipple behind the map sensor, so you won't see the vacuum connection until you remove the map sensor.
kastein NAXJA Member NAXJA Member Location Rainy side of Washington Apr 19, 2012 #4 the MAP sensor is kinda important... you're just removing it to check the vacuum connection or replace it right?
D dobesrgrt NAXJA Forum User Location PA. Apr 19, 2012 #5 kastein said: the MAP sensor is kinda important... you're just removing it to check the vacuum connection or replace it right? Click to expand... Checking connection right, if the wife gives me a chance to. Put string on the weed wacker get the riding mower out of the garage. Do we have any gas, can you move the picnic table. HOLY CROW already.
hubs97xj NAXJA Forum User Location Fort Wayne, IN Apr 20, 2012 #6 Sensor has a nipple, throttle body has a nipple. Connection between MAP and Jeep is just a short rubber elbow. Kind of visible in pics. http://i266.photobucket.com/albums/ii244/AHhub/throttle body- remove taper/DSCF5435.jpg http://i266.photobucket.com/albums/ii244/AHhub/TB.jpg
C comanche91 NAXJA Forum User Location Sweet Home Alabama Feb 23, 2014 #7 Does a new rubber vacuum elbow come with a new MAP sensor (96+ throttle body mounted)? If not, are they available anywhere? Last edited: Feb 23, 2014
C comanche91 NAXJA Forum User Location Sweet Home Alabama Feb 23, 2014 #8 EDIT: Did some research - so to answer my own question above: no it does not. However it's still available from the dealer, about $3, p/n 53009672
