vac lines tb?
bamajeepjunkie said:
both are open now is your's an automatic or does it matter it does idle high
One of those holes should be blind (no hole through it), and the other is a vacuum port for the MAP sensor (the one on the firewall). I've forgotten which hole is which, but if you look carefully it should be obvious. The line from the MAP sensor is supposed to have a double plug on it, with one part that goes into the blind hole, and one that actually communicates with the vacuum port.
