VAQUARO
- Delta B.C. ,Canada
'90 2.5 4 cyl. w/ plastic valve cover ....tired of trying to RTV seal , going to Fel-pro dry gasket ,problem is the OEM bolts have a shoulder intended to used to define the RTV thickness and will not work with pre-formed gaskets (dealer no longer lists and has no specs )
