Using a larger oil filter on a Renix
1990JEEPXJ
San Diego
well as many renix owners know, there arent much in the way of oil filters out there. at least not the the extent that there are for the HO 4.0's. but there is a way to be able to use tons more oil filters, including the same ones HO 4.0's use. the reasons for doing this are more options for oil filters, and larger oil filters which is always a good thing. so i will go over how this is done, its very simple
here are the parts:
new filter- Purolator premium L30001, old filter, new adapter
first you obviously remove the old oil filter.
heres the adapter. any dealer stocks this part and it's around $7.
you will also need to remove the housing as well with a 16mm wrench
after you remove the housing, you will need to remove the threaded adapter inside the old housing and replace it with the new one.
but in order to remove the old adapter, which is a few inches long, you will need a crescent wrench to remove the old one, but chances are that it is stuck in there pretty good. so i had to cut off the unthreaded portion of it in order to get a 22mm socket on the adapter. i recommend wiping down the housing before you cut it.
once you cut that off you can remove the adapter with the wrench. you will need to use compressed air, brake cleaner or something to blow out the metal shavings in the housing. and after that you can install the new threaded adapter, either side works as they are both the same. i had to use a crescent wrench to tighten this one as i didnt have the right size socket. but be careful not to nick the sealing surface that the filter will be against.
this is also the perfect time to replace the housing o-rings, also a common dealer item.
after you replace the old o-rings you can install the housing and new larger filter.
and here is a list of what oil filters you can now use on your renix:
LARGER THAN STOCK (note: most of these can be used on a stock 91+ XJ with the horizontal housing. they are also readily available at most parts stores)
Ford FL-1A
Wix #51515
Napa #1515
Amsoil EaO15 "Nanofilter"
Baldwin B2
Baldwin B2-HPG
Bosch 3500
Denso 150-1004
Donaldson P169071
Donaldson P550008
Fleetguard LF3313
Fleetguard LF3487
Fram HP1
Fram PH8A
Fram TG8A
Fram XG8A
K&N HP-3001
Mobil 1 M1-301
Mobil 1 M1-301EP
Motorcraft FL-1A
Professional's Choice Q1A
Purolator PremiumPlus L30001(the one i used in this write up)
STP S8A
Supertech ST8A
MUCH LARGER THAN STOCK (note: these can ONLY be used on renix XJ's with with vertical housing. and these arent as easy to find in stock at most parts stores, though they can order them)
A/C Delco 2142 (forgot the leading letters)
Fram PH977A
Napa #1773
Wix #51773
Motorcraft FL-299
FL-299 Equivalents
Baldwin BT237
Baldwin BT251
Donaldson P550299
Donaldson P554407
Fleetguard LF697
Purolator PremiumPlus L40017
"GIGANTO" Filter
Napa 1714/Wix 51714
and where i got the list from:
More than you want to know about 3/4x16 oil filters(and some for 20x1.5 too)
Nice write-up. Can I use the Amsoil EaO15 without changing to the new adaptor? Eventually, I'm going to install an oil by-pass system.
Nice Thanks for posting. I want to install a duel external system on my XJ and run 2 of the Wix Gigantic filters!!
