vetteboy
- morganville, nj
Currently in the progress of a stupid big XJ build, parts of which include a 4-link rear and 3-link front w/panhard.
The front is getting set up on a Dodge D60, low-pinion. The single upper link (much like the URF-style) will run on the drivers side, which since there's no longer a transfer case on that side, leaves a lot of room for flexibility. Also since the trans is a NV4500 I've got nearly 10" above the crossmember to play with on that side, and I can angle the link to meet the axle pretty much anywhere on the right half of it.
So...the problem is the Dodge D60, which came with 5* of caster and 0* of pinion angle. I'd like to keep at least 3* of caster in there, which leaves me with a somewhat lame u-joint angle at the pinion. I'm running a small enough amount of lift that the angle is fine at static height, and it's fine if the diff drops down 6", as long as the pinion doesn't rotate down at all. What this works out to is that as long as the lowers and uppers are equal length, or the uppers slightly longer, I won't run into any u-joint issues.
(yeah, I know I can cut/rotate the inner C's...trying to avoid that if possible right now)
I know for the rear that keeping the upper links shorter, while not helping pinion angle any, lets you take advantage of the change in anti-squat over suspension travel. The big question: how much will this matter in the front, if I keep the upper link equal or slightly longer? Will it tend to unload more, give more torque rise, etc? I totally understand how the rear works but can't quite picture how the weight transfer will affect the front.
I guess specs would help. Lowers around 38-40", upper can be 33-43" with the available clearance. Currently sitting at around 90% anti-squat by the 3-link calc. Around 6" vertical seperation at the frame and 7 - 7.5ish at the axle.
I'll be posting a full write-up of this thing eventually, when I can get all the pics and stuff organized.
