- REDLANDS, CA. (SoCal)
Output control option:
http://youtube.com/watch?v=busFhbGwPLw&feature=related
Harlee&Tahoe said:I haven't seen this before but its theory sounds like it may help those having O2 issues.
It's a O2 tweak and AFR meter you can make at home.
I've seen a kit for less than $30.
http://better-mileage.com/memberadx.html
I don't understand your response.Ecomike said:This part caught my attention!
"[FONT=Arial, Helvetica, sans-serif][SIZE=+1]Since installing this device and the steam injection our mileage has improved approximately 18%."
They are using steam!
[/SIZE][/FONT]
Harlee&Tahoe said:I don't understand your response.
They are using steam! As in this doesn't apply or WOW They're using steam.
I didn't look at as in conjunction w/steam but more as a neat way to monitor AFR with standard O2 sensor and adjust accordingly all with things you can buy from Radio Shack.
lawsoncl said:Can someone with a working unit measure the current draw when its running, and maybe measure the gas volume output?
If I could build one for say, $20 I'll build one this weekend and fiddle with it.Timmy2XJS said:iv been eyeball deep in this the hho stuff and there seem to be a shift to using white distilled vinegar. i dunno if that will help you out any. im goin to be butting one of these units on my 88 at the end of the month and goin the vinegar rout. ill share with the class my results when i get em
Timmy
Brass would be a very poor choice. You want a metal that will not disolve into solution, brass, zinc, copper, aluminum and steel all disolve into solution.PuddinHead said:I watched a Vid on U-tube that showed the assembly of an hho generator using pvc pipe. One electrode was made up of an assembly of stainless steel washers and lockwashers on a stainless carriage bolt. The other electrode was a piece of stainless sheet metal rolled up and mounted to the inside of the pvc pipe. I don't have easy access to a sheet of stainless and thought a brass pipe nippple with an O.D. about the same as the I.D. of the pvc pipe would work just as good. Is this a bad idea?
tbburg said:PuddinHead: A cheap source of stainless: get a stainless pan/pot from walmart/Kmart/etc.
Ecomike said:Brass would be a very poor choice. You want a metal that will not disolve into solution, brass, zinc, copper, aluminum and steel all disolve into solution.
Timmy2XJS,
I too have looked at the vinegar (Acetic Acid) option as a mental excercise, but keep it mind it is volatile (evaporates). I suspect a good bit of the vinegar evaporates and gets burned in the engine, and therefore needs more frequent replacement which may be costly, and time consuming, but I would be interested in seeing comparative results.
I have also thought of ammonia, or ammonium hydroxide, but I have not read of anyone trying it yet. The nitrogen in the ammonia may be a problem for NOx emission requirments.
Timmy2XJS said:....the unit i am goin to get is by magdrive. its a new brick unit ........requires less maintenance than the solution, and you get a significant more hho from it.
Magdrive lost a lot of credibility as soon as I read this: http://www.fuelfromh2o.com/how-it-works.html "A fallacy out there is that it takes more energy to produce the HHO than the energy it releases. Not at all true"Ecomike said:Brick unit? Less maint...than solution????
