Rushin
- Minneapolis, MN
In the description it says it will work like an athetolyn torch and can cut through sheet metal. I mean it uses same components that big torches use. Hmmm
Let us know how using a torch goes around that fuel filler neck. The work required to do that safely is more than a few minutes with an angle grinder.
Do you think there is any chance I could use new shackles with the hole I am using now? I was stupid and did not cut the bolt hump for stock shackle. So I would have to tear it all out, cut the hump and put it all back together to be able to use those two last holes.
BTW I ordered RE 5" http://www.rockridge4wd.com/i-21252...greaseable-5-84-01-jeep-cherokee-xj-pair.html
They sort of have a revolver kink to them so that might help a bit too....
So I got the shackle relocation brackets in with RE 5" shackles. The ride is significantly better. Spring rate certainly dropped quite a bit. The back end is still pretty high in the air vs the front. I need to remove the brackets and cut the bolt hump down so I can use other holes that give less lift.
I have the same setup as you except I removed one leave from my leaf pack to lower the rear about an inch. I'm happy with the current ride height. See the photo.
[/url][/IMG]
Dude! Thant looks amazing.
1. Which leaf did you take out?
2. What hole did you use on the bracket?
3. What size tires do you have?
4. Did the ride get softer with removing one of the leafs?
5. What front bumper do you have? It looks awesome.
1. The bottom (shortest) leaf.
2. Same hole as in your photo. I have IRO boomerang shackles.
3. 245/75-16. They are 31's. I went with 16" wheels to have room for bigger brakes later. I'm used to much better braking from my other cars.
4. Yes.
5. JCR bumpers front and rear.
How much better did the ride get? Even with the new shackle and relocation boxes the ride is still ****ing awful
