rooneypower
- Woodinville, WA
will do
Blaine B. said:If you go the rubber line route and don't flare, double clamp each end of the hose.
I did that and no leaks.....on tranny cooler lines, on my XJ.
5-90 said:I have also found it helpful to smear some RTV Black over the outside of the metal tube before you slip the rubber line over it, then double-clamp. Overlap by a minimum of one inch, leave about a quarter-inch of hose between the clamp and the bitter end, and leave about a quarter-inch (or more, if possible) between clamps. All of this will help to ensure a good seal.
And use a tubing cutter, not a hacksaw! A cutoff wheel in a Dremel is iffy - deburring is mandatory with abrasive cutting on tubing! A tubing cutter (the one with the rollers backing up where the tube contacts a cutting wheel) is ideal, as it will give you a clean edge that won't abrade through the hose. You can get small tubing cutters fairly cheaply at hardware stores.
Don't push the cutter - the slower you go, the better the cut. I usually tighten the handle to contact + 1/4-turn. Go around the tube once or twice, tighten another 1/4-turn, and repeat. Continue until the tube separates. A nice, clean cut.
alexer03 said:I do believe a oxy-aceteline torch will give you that nice clean deburred cut your talking about...
:smoker:
-Alex
5-90 said:Nope - OA cuts usually have slag to chip or grind off. So do plasma cuts. The thicker the material, the more slag you get (even when you cut with pure oxygen):nono:
Besides, a small tubing cutter is cheaper, and you'll probably use it elsewhere (got a fridge with an icemaker? Do any light plumbing work?)
alexer03 said:Ha thanks for taking me seriously? I think, I was joking since I know the guy and he might try that... :doh: Sorry for the confusion, ill be more blatant next time.
-Alex
:smoker:
-Alex
monkeyevil said:Like said before... the quick fix is to cut out the bends and use some power steering or trans cooler hose, and some clamps.
Taking a little more time would be to cut the kink out, flare each end, and add some new tube in with flare nuts.
The best way to fix it would be to run new lines entirely. Using either the stock parts, bending your own, or running good quality rubber line the whole way.
ColoradoRaptor said:Ok, this thread has gone on long enough!!!!!A bandaid will always be a bandaid for god sake! Do ya want to be out on the trail and blow your bandaid all over the place? Fix it right or take the heep to the dealer and pay them to do it!!:doh:
