J jeepspeedster NAXJA Forum User Location So Cal Apr 5, 2004 #1 Lost the u-joint out of 1997 XJ with Chyr 8.25, It is 2wd with 33 inch tires, are there other option other than OEM size?
Yucca-Man NAXJA Member # 683 Location Castle Rock, CO Apr 5, 2004 #2 Not without changing the yokes...
8Mud NAXJA Forum User Location Central Germany Apr 5, 2004 #3 Take a close look at the differential yoke and pinion, at full compression I´ve crushed the collapsible sleeve a touch on the 8.25, the pinion gets pretty loose. Could be what jammed and popped your U-joint.
