Turn signal problem...
tauber
Doylestown, PA
i did a search for this problem, to no avail. at first i thought my right rear turn signal was inop. then when i removed the right rear light assembly and pulled the turn signal bulb with the turn signal on i noticed the turn signal bulb was barely blinking. the bulb filament was lighting up ever so slightly. i've come to my wits end with this one. its a green 94 jeep cherokee sport with red trim on the bottom. Please help. Much thanks.
I THINK the bulb grounds to the socket, so I would pull the bulb out and check for corrosion on the bulb or socket or any dirt or grime that could make the ground weak from the bulb to the socket.
