tealcherokee
- CT
turbo stroker -> 23 spline aw4 -> np242 locked in full time -> hp30 front w/ TJ crmo shafts and a d44 rear
spinning 255/55-16's general grabber UHP's on the street
and 245/60-16's mt's for the dirt
black steelie wheels 16x8, 5" back spacing, puts the jeep a total of 2.5" wider
rear is currently stock, soon to be mid link, single triangulated, 4" travel coilovers, 1.5" down, 2.5" up, sitting 2" lower than stock
front is going to be 3 link w/ panhard, mid arms just like the rear, 4-6" travel coil overs, 1.25" down, 2.75-4.75" uptravel, not sure what i want to go with yet. not sure on spring rates yet, probably 300 up front, 225-250 rear, keep it nice and stiff, running factory sway bars, with beefed up links and mounts.
poly mounts on all soft joints, RE flex joints on the hard ones
custom RE flex joint motor mounts, fixed tranny mount w/ poly isolater (RE's dont give, but still allow the motor to rock, so the tranny mount needs to be solid as well)
removing the gas tank, sinking the rear cargo area down about 4", fuel cell inside, -6an for all fuel lines
removing the front crossmember, makeing a tubular drop crossmemeber, and room for a full size chevy, 4 core aluminum radiator
external tranny cooler mounted infront of the radiator
top mount intercooler, or meth injection, not sure which yet
muffler and cat-less 3" turbo back exhaust, splitting into dual 3" with 4" stainless tips exiting under the rear bumper
fully gutted interior, EOR 10 point jeepspeed approved roll cage
summit racing buckets
custom dash
i think that should keep you busy.....
custom dash
