Doh, look what I went and started. :doh:
Cracker and Begster gave a clearer definition on what I was attempting to say. I wasn't speaking of the housing itself, but rather that of the weakness is coast vs. drive sides of the ring gear. Thanks guys.
Scott
Not to worry Scott. you did a great job explaining everything else though :cheers:
Troublemaker. :cheers: I think I would like a list of people who have actually witnessed LPD44 ring gears giving up the ghost - I think it will be a short list. I understand the engineering and that technically the LP ring is weaker in a front application, but I have wheeled with several YJ owners on 36-38" tires, locked, on LP D44s and never seen a failure. It is more than enough girth for nearly everyone, IMHO. :lecture:
You are absolutely correct. The list would be VERY short and would have to be with a lot of power and probably some really crappy driving. The low pinion D44 with our power plant (tired 4.0s) is more than adequate to withstand some good wheeling.
Keep in mind the Waggy 44 was spec'd in a rig that had a AMC 360 in it (as an option) and weighed 1000# more.
Of course a high pinion would be better for clearance though.....
