lawsoncl
- North Idaho
/screenshot of very first page in this thread/
Yes, the above is correct. Welcome to !
AFAIK, the only info is from the TCU checking in to say it's alive or it's got a trouble code. The TCU handles the shifting independent of the engine computer.
That's not all, the ecu also reports the map, throttle position, and the manifold vacuum. The TCU compares that to the output speed sensor to help control shift points and torque converter lock-up.
That's not all, the ecu also reports the map, throttle position, and the manifold vacumm. The TCU compares that to the output speed sensor to help control shift points and torque converter lock-up.
That's interesting. The TCU has a dedicated signal wire for the TPS, so not sure why it would need it via CCD bus as well. Map and manifold vacuum are the same thing.
I do not have any good info on this though. It is something I would like to know, but I will need to take the data collection myself to really be happy with putting my name on a list of data points it shares with the ECU.
I have a 95 XJ and am thinking of swapping in a 98 AW4.
From the write up at beginning of this thread it says that a change to the t-case input gear is required.
"1998-2001 AW4s require more work. All the transfer case input gear info from 1990.5-1997 applies, on top of that, the sensors have changed!"
I see that both years have the 23 spline output shaft in the auto so whats different or needs changing?Sent from my SM-N960F using Tapatalk
Unless you plan to swap some internals between a pre-98 AW4
I dint know about your plugs but lawsoncl is wrong. I put a 2000 aw4 in my 95. You only need to change the reluctor wheel and extension housing and change the trans wires slightly, most people drop the pan and just swap the harness, but mine was to brittle so I just cut and soldered.
I do not know for sure but I think it is pretty unlikely. I am not comfortable answering this any more definitively than that without actually reading the TCU firmware code, which I have wanted to do for a decade now but have been unable to buy the adapter board to put the TCU MCU in my EPROM programmer anywhere for less than several hundred dollars. Since this is a hobby project that is well outside of the amount I am willing to spend.What are the chances that the TCU would receive and use engine RPM and manifold pressure?
I need to go re-read my own first post and make sure I didn't make a mistake on that I suppose. The intention was to indicate that 90 down vs 90.5 up (possibly 90 vs 91, my info sources differ on this) are 21 vs 23 spline so you would not need to change your input gear between 95 and 98. However the OSS pulse count and signal type (reed vs variable reluctance) are different as everyone has already noted and this will not work right without swapping at least the reluctor wheel, tailhousing, and sensor. Additionally the output shaft is actually slightly different between 97- and 98+ (the snap ring grooves are in different places) and you may or may not be happy with the half-assing that is necessary to make the wrong year reluctor wheel fit a given output shaft. This all leads me to generally recommend staying with the correct year range transmission as there is typically no shortage of them, they fail rarely enough that the availability is high and the price is low.I have a 95 XJ and am thinking of swapping in a 98 AW4.
I have had a 2000 aw4 in my 95 for over 100k miles and can confirm it works fine by just changing the reluctor wheel and tail housing. (And necessary wire changes.)I do not know for sure but I think it is pretty unlikely. I am not comfortable answering this any more definitively than that without actually reading the TCU firmware code, which I have wanted to do for a decade now but have been unable to buy the adapter board to put the TCU MCU in my EPROM programmer anywhere for less than several hundred dollars. Since this is a hobby project that is well outside of the amount I am willing to spend.
