Trucklites on my 97+ Manche
Rockdrummer93
Greenville, SC
Anybody run trucklights on here? I have a set in my 97+ Comanche and I believe they are glitching out. High beams and low beams on at the same time. I’ve put in resistors, replaced the headlight switch, and multifunction switch and still the same issue.
I cannot respond to the trucklites since I am not familiar with them. What I do know though is,. If the bulbs are not grounded properly then both filaments high and low come on at the same time. Check the ground going to the bulbs.
I got them fixed today. Turns out it was an issue with the fog light circuit. Pulled the relay for those and the headlights work fine.. never would have thunk that
