dysfunctionaljd
- Jonestown Texas
So if you already have an upgraded harness, do you need to remove it to use these, or will these still work with the harness, but will look pretty much the same as stock?
^ Another thought would be if you see such cold temps and snow, would the LED's produce any (or enough) heat to keep the lights from freezing over when driving?
A new harness will always be better than stock even if the larger wire is not completely necessary.
Vibration will shorten the life of a filament bulb whether it's on or off.
But LEDs are cool running; keep that in mind for snow/ice accumulation.
A nice wax over the plastic (never RainX) might help to shed the mess but it's not like having a hot bulb.
The LEDs only need a nominal 9v to work; a harness is only necessary if you suspect shorts or the OE failing in some way.
Anything with a petroleum base to it will interact with the polycarb at a molecular level and cause "crazing" ---- the lens will turn milky.I’m sure using a deicer on the lens would be frowned upon?
I use Plexus on my plastics.
As far as de-icing goes, hmmmmm. Maybe we can check with Jerry at Trucklite or John at JW Speaker...
I imagine it would look very similar to the 96 and down...the lights won't change at all.I would like to see a set of LED's in a 2000/2001 XJ. Hopefully somebody will purchase and post pics soon!
