joe_peters
- Grants Pass, OryGun
Ok, because you are loosing ignition and radio and etc., all SWITCHED circuits, while your headlights and cluster lights remain, all UN-SWITCHED circuits, then I would put my money on the ignition switch.
Not the key, but the ignition switch at the foot of the steering column. When you turn the key a remote rod attached to the lock cylinder acts upon the ignition switch, moving it so that the contacts can complete circuits in ON/START/ACC/OFF. Go there and check it out. They come loose and flop around, the contacts overheat and the connector needs to be replaced, etc.
