XJFever
- Anchorage, Alaska
So......Getting kind of desperate here. Anyone have any solutions?
I'm not sure if you can see everything but this is what he replaced.
lookint at t-case
looking towards axle.
I spent 30 on one driveshaft and 0 on the other. I had the time to put them on, so I tried it. The hubs are like 200 a piece. I figured 30 bucks was better then 200. The t-case was also free. More like a trade. So I tried that. I found out my hubs are worn AFTER all of this. Midas actually said they were bad, so they might just be trying to get me to spend money.
noso did the problem ever get fixed
no, but can you explain that a little more to me?Did you shim your pinion for proper angles after the SYE install?
The pinion bearings can make the noises you described. You must remove the carrier to get the pinion bearings out. You should not need to have the gears re-setup if you don't move any shims around. Just make sure it goes back together exactly as it came apart. Also make sure all fasteners are torqued to the proper specs.Ok i am bringing this thread back to life partially cause this dude never indicated he got it fixed, and because i have the same issue: a whine/growl in 4hi and 4lo only under power and high decel coast ( slowing down fast in 4low just because its in 4low.)
-did a full transfer case rebuild kit with chain and sprockets and all the goodies and transfer case mount....
-----no change
-new front drive shaft...
-----no change
-New hub assemblies, Ujoints, and ball joints
-----no change
the only thing i can think of next is front gears/bearings. maybe pinion bearing... i did some searching and found nothing extremely conclusive, but it is possible to replace the pinion bearing without tearing apart the whole shebang?
axle spec: d30hp with 4.56 gears
TC spec: NP231J with RE hack and tap
