camarors8992
- Liverpool, New York
Lets start with the trouble codes, light came on today so i stopped at Advance Auto Parts and they pulled and printed the codes for me. Here's what was shown.
If it matters at all, I filled my gas tank last night and 2 days ago replaced the downstream o2 wiring since it had been missing for some time. I replaced the downstream o2 several months back the same time I replaced the catalytic converter but the sensor was never hooked up due to the connector being MIA.
Onto the death wobble, and I'm sorry I know it's such a common issue. I've thrown so much money into the front end of this Jeep and i'm getting tired of it. Things I've replaced, ball joints, 3/4 tie rod ends, wheel bearings, axle u joints, and the tires. I've removed the differential side of the track bar with intentions of replacing the bushings, but after removal i noticed there was no play at all on either ends so i just re-installed it. It happens at 55mph to 63mph. I know my axle u joints aren't as tight as they should be, same with the wheel bearing, but replacing those has never cured it before.
I took video of the steering wheel, to show you what it does. It's kind of hard to see, but you should be able too. You can also see how the think wanders around too, it's almost scary on a posted 55mph country road.
