Mr. Roboto
- NH
Every time I turn my 99 XJ off, the trip resets to 0. I'm assuming that this information is stored in the cluster, and that the cluster is not getting a constant 12V supply when the Jeep is off.
When I first got the Jeep, it had been sitting, and the mice got into the wiring. I stripped the interior, headliner, kick panels, glove box, most of the dash etc and repaired several chewed wires. My IOD circuit is now operational and has not blown a fuse since I made the repairs. My dome lights work, vanity lights, radio settings retained ect. The last lingering issue is this trip memory retention.
Does the cluster in fact get supplied with a constant 12V? If so, which pin is it? I attached the wiring diagram for the cluster connectors, but none of them are explicitly labeled constant 12V. I figure that if it is supposed to receive a constant 12V, it will be easier for me to just splice a new wire to that pin than chasing down the actual issue.
Thank you!
Thank you!
