- 29°58'28.9"N 99°15'15.5"W
Today I Changed the oil in my '00. I pulled the plug out of the bottom of the pan and losened all of the bolts on the pan, blah blah, blah. When I tried to remove the pan the dipstick tube would not come apart. I squirted WD-40 on the joint and let it sit, I tried to wiggle it to free it loose, I tried twisting it. Finaly I went to the top of the motor and took out the bolt that holds the tube to the block. OK to make a long story short, After I got Tranny fluid in my hair soaked in my clothes the tube came apart. What do I do to not let this happen again? Never sieze? Any suggestions?
