CaliXJ NAXJA Forum User NAXJA Member Location Oceanside, CA Jun 26, 2012 #21 Vanimal said: it's because jeeps with automatics were only meant to get knobbers on the trail. If you have an ax15 you won't get them at all. Click to expand... fixed:yelclap:
souske NAXJA Forum User Location The land of competition Jun 26, 2012 #22 Vanimal said: FIFY Click to expand... Bootyfab
Vanimal NAXJA Forum User Location escondido, ca Jun 26, 2012 #23 CaliXJ said: it's because jeeps with automatics were only meant to give knobbers on the trail. If you have an ax15 you won't give them at all. Click to expand... NOW it's fixed
D Dirtoyz NAXJA Forum User Location North Quabbin MA Jun 26, 2012 #24 If you have poly motor mounts how much would your trans move? They have to lessen the movement somewhat.
Vanimal NAXJA Forum User Location escondido, ca Jun 26, 2012 #25 the problem would be if the motor moved and the trans didnt, or vice versa. i guess it could crack the bellhousing.
rockclimber Associate NAXJA Member Location San Diego Jun 27, 2012 #26 I have rubber mounts now. going to change everything over to poly.
souske NAXJA Forum User Location The land of competition Jun 27, 2012 #27 Vanimal said: NOW it's fixed Click to expand... An auto will bleed red fluid on the trail, and have vibes from poly mounts An AX-15 has a large appendage and prefers rubbers If you guys like giving knobbers trailside, that's your own business.
5-Speed XJ NAXJA Forum User Location Sunapee, NH Jun 28, 2012 #28 its usually the tail housing that will break or the t case when you mix rubber and poly mounts
