dan1977p
- Virginia Beach, VA
I've had an odd fluid leak that I've been hunting down for a while. The next step that I think is to replace the front pump seal on the transmission. I just replaced the rear main hoping the leak would subside and the area around that seal is perfectly dry but I'm still getting fluid coming out of the bell housing.
Main question, how hard is it to replace this front seal? On or off the Jeep? I've been wanting to drop the tranny so I can clean everything up under the jeep as well as clean it up so I may pull it anyway with the TC so I can reseal the TC properly too.
You can stop here if you don't care about the back story.
It only blows fluid if I've been running 80mph (3000rpm) for at least 10-15 minutes after it's warmed up completely. Once I've been running 80 for a while and let off the gas, I get a huge steam/smoke cloud out the back from fluid being dumped onto the exhaust and it completely covers everything behind the bell housing and I can't tell if it's ATF or engine oil. It's redish right now since I just cleaned as much as I could but I used AMSOIL for the engine that also has a red tint to it so... I've cleaned everything up from the valve cover down and there aren't any leaks prominent enough to cause this much loss smoke and it only happens after long high RPM runs so it seems more like something with the crankshaft anyway. Also when I let off the gas, I get a good vibe that I've always attributed to a slight misalignment of the rear DS, but maybe it's a bad bearing at the front pump that's caused that seal to fail but it only dumps fluid because maybe I'm sumping that pump? Any advice is appreciated.
