Transmission Cooler line O rings?
Heavyopp
Middlesex, NJ
I'm adapting my AW4 trans cooler lines over to AN hose using --Earl's Performance AN to Metric Adapter Fittings 9919DFHERL
Everyone says these are O ring fittings on the metric side to the trans -- What size o rings? 14mm ID should be but what diameter is right? Are these really supposed to be used with O rings on the transmission? I'm not entirely sure...
O rings aren't sold with the adapter and they are not linked in the "suggested Parts" section of the adapter listing
Anyone have a part number from Summit racing for them? Been searching for an hour and I come up with nothing
Thanks for any help
I have never used o rings with the adapters.
IIRC i use a brass washer similar to what a brake line uses.
I did this same conversion a few years ago (using the same parts). I came across the following part on a few forums, used it & it is still sealed up great.
https://www.amazon.com/gp/product/B005RUSZ9G/ref=od_aui_detailpages00?ie=UTF8&psc=1
That looks about right -- now it's me being cheap -- $11.16 for 10 O rings when I only need 2...
I did a chat with summit earlier today -- Asked them what O rings to use
they came up with these: https://www.summitracing.com/parts/ear-176006erl/overview/
Says they are -6 an O rings -- I don't need them for the AN side of the fitting, trying to find specs on this ring, ID,OD and thickness
I'm wondering if -6an O rings would be 14mm ID -- and these are $3.95 for a pack of 10
What a PIA... -- you would think they would sell the O ring with the fitting when it's specified "O ring required"
SO had a chance to check some dimensions
-6an is 9/16 - 18 thread
9/16th is 14.28 MM so the -6an O rings should have an ID of somewhere really close to 14 mm
I think my adapters came with o rings. My sending unit adapter came with a copper washer. I would not hesitate to use washers. Could go to parts store and just grab some copper or aluminum washers.
If you want to use an o-ring you can go down to NAPA with your part and they will help you find one. They have a box with 30 different sizes and sell out of it for 99 cents each.
I ended up adding the Viton O rings that are labeled -6an to my order -- it was $3.95 for a bag of 10
We'll see what happens once they get here
If these are wrong I will go to Napa either get a proper fitting O ring or copper washer
As expected those 14mm ID o-rings are way too big.
These things have to be tight against the bolt and the orifice in order to seal.
The one on the left is the stock o-ring from the temperature sensor port (14MM w/ T55 head). The one on the right are some that I bought from NAPA that are close-10MM ID x 2.5MM thickness = 15MM OD
This is what they look like on the 14mm x 1/8 NPT adapter bung and the AN fittings
Snug on the bolt and on the orifice. A little big but they go in with some tranny fluid for lube
Parts came in -- O rings look fine -- I took pictures but have to find a new photo hosting website since the new photobucket restrictions
Ended up with EAR -176106ERL for O rings
The fit snug over the threads and just slightly loos when seated in place below the threads, Should work fine but I'll know better when I pull the current hardware out of the transmission
Suggestions for photo hosting websites???
